Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Where do I find default configurations?
    • AC890 Series-
  1. Choose file, New, 890
  2. Select Firmware version (Templates for older firmware revisions are also listed)
  3. You should only install templates for the firmware version in the inverter (Attempts to load incorrect firmware version may damage equipment)
  4. The template may not be a later revision level than the installed firmware
    1. Version 1.x is for Induction motors only [Obsolete]
      1. Only v1.7 and v1.9 templates are available
    2. Version 2.x is for Servo motors only [Obsolete]
      1. Only v2.3 and v2.4 templates are available
    3. Version 3.x is for Servo Induction motors and is used for most applications
      1. Many templates are available for best results use the latest version
    4. Version 4.x is for CAMMING applications only [Obsolete]
      1. Only one template available
    5. Version 5.x is for GRID TIE applications only
      1. 5.1, 5.2, and 5.3 templates are available
  5. Select the MACRO for DEFAULT or for AFE application
  6. Customize the configuration to meet your application needs
  • How to determine what firmware your 890 is, see this FAQ.
13SEP2016 LS
14May19 JD
  • find
  • DSELite
  • dse890
  • DSE
  • where
  • default
  • configuration
  • 890
