Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How do I know what firmware revision my AC890 is?
    • AC890 Series-
a. There are different firmware Versions based on the type of application
i. Version 1.x for Induction motors  -no longer supported - USE V3
ii. Version 2.x for Servo motors - no longer supported - USE V3
iii. Version 3.x for Induction and Servo motors (v3.x is the default)
iv. Version 4.x for CAMMING applications - no longer supported
v. Version 5.x for AFE and EGT applications
b. On the 6901 keypad
i. Depress the [E] button on the keypad until you see the Application name
ii. The next line will give the Hp, voltage and firmware version
c. On the 6511 keypad
i. Depress the [E] button on the keypad until you see the firmware version
d. Connect to the inverter using the CM471050 cable
i. Open DSE Lite software or DSE
ii. Ensure you are using the correct COM PORT for your CM471050 cable connection
iii. Select the Get Info button
iv. The type of drive and the firmware version will be displayed in the scratch pad
13SEP2016 LS
14MAY19 JD Updated
  • determine
  • firmware
  • what
  • 890
