Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What software and communication cable are used for programming an AC890?
    • AC890 Series-
See this FAQ for more 890 information on cabling, software, and downloads.
  1. For stand-alone drive configuration DSE Lite software is used.
  2. For Systems configuration DSE (previously called DSE890) software is used.
  3. The programming cable is a standard USB USB-2.0 cable (part number is CM471050).
  4. If the AC890 has an Ethernet communication card installed, communication can also be accomplished via Ethernet if using DSE.
13SEP2016 LS
6NOV19 JD Update
  • cable
  • software
  • 890
