Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What can I use to replace an 8902/RR/00/00?
    • AC890 Series-
a. If you only need resolver feedback,
i. 8902/RE/00/00 for the resolver feedback.
b. If you only need resolver feedback, and an encoder repeater,
ii. 8903/EP/00/00 for the encoder repeater.
c. If you only need resolver feedback, an extra analog input, and an encoder repeater,
ii. 8903/AI/00/00 for the analog input and the encoder repeater.
13SEP2016 LS
  • resolver
  • 890
