Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What kind of I/O is available on the AC890?
    • AC890 Series-
This information can also be found in the manuals and catalogs:
For I/O that is configurable see the FAQ.
How many analog inputs are on an AC890?
  • The AC890 has 4 configurable analog inputs, rated for -15VDC to +30VDC. The Analog Inputs can be configured in software for ranges of 0-10V, ±10V, 0-20mA or 4-20mA. All analog inputs have 12-bit resolution, (plus sign bit). The inputs are scanned approximately every 5 milliseconds. One selected input can be scanned every 1 millisecond.
How many analog outputs are on an AC890?
  • The AC890 has 2 configurable analog outputs with ranges of 0-10V or ±10V. The outputs are scanned approximately every 5 milliseconds. The analog outputs have 12-bit resolution (plus sign bit).
How many digital inputs are on an AC890?
  • The AC890 has 9 configurable digital inputs, all rated at +24VDC. The inputs are sampled approximately every 1 millisecond.
How many digital outputs are on an AC890?
  • The AC890 has three configurable digital outputs. Two are current sourcing outputs, DINOUT1 and DINOUT2 rated at 24V. The maximum output of all 24V sourced outputs is 160mA (i.e. iDINOUT1 + iDINOUT2 + i24V USER < 160mA) The third is a pair of volt-free relay contacts, DOUT3A and DOUT 3B rated at 24V SELV with a resistive load of 1A.
  • available
  • I/O
  • 890
