Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 890 - Interact Xpress with the AC890
    • AC890 Series-
The following two files provide an example of how to configure a Parker Interact Xpress HMI project and a Parker AC890 drive to achieve communications and allow for data transfer.  The attached examples make use of the generic Modbus Ethernet driver.  This sample will work with either the 8903/IM card or 8903/LN card installed in the AC890.
For help setting up Modbus on the AC890, open DSE890 or DSE Lite and click Help > LINKnet Support for 890 > Product Manual.  For help setting up Modbus on an Xpress HMI, open Xpress Manager and click Help > Interact Xpress CommServer Help.
AC890 to Xpress via Modbus Ethernet
Thanks to our distributor Olympus Controls for this contribution.
glh Feb-2013
17DEC2020 DCLIFFE - Migrated from old FAQ site.
  • Xpress
  • communication
  • Modbus
  • 890
