Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Misc - Absolute Encoder Compatibility (BiSS-B and BiSS-C)
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
Beginning with firmware version 4.42 IPA servo drive controllers support BiSS-C and BiSS-B encoder feedback.
Parameter C171 tells the drive what feedback will be connected.
C171=5 for BiSS
when C171 is changed, the drive needs to be power cycled or issued the REBOOT command to implement the change.
ACR-View 6.4.1 supports BiSS feedback. Prior to downloading the motor file ACR-View will check the current value of C171 and if the new value is different a REBOOT command will be issued following the motor file download to enable the new settings.
in addition to C171 three other parameters are required for BiSS set-up.
Parameter Description
C168 Number of valid bits= single turn + multi turn
C179 Set-up value
C180 Multi-turn value
These parameters are included as part of the motor file download in ACR-View for the following Parker motors.
Parameter C168 C179 C180
Description valid bits Set-up value Multi-turn value
PM-FAL w/o battery 34 37752853 65535
PM-FBL w/o battery 35 37752853 65535
PM-FCL w/o battery 35 37752853 65535
PM-DD 20 41943061 1
MX80L 26 33554458 1
PM-FAL w/ battery 34 33558549 65535
PM-FBL w/ battery 35 33558549 65535
PM-FCL w/ battery 35 33558549 65535
BiSS ENCODER PIN-OUT
IPA Pin BiSS Function P Encoder cable Wire
1 SLO WHITE
2 /SLO WHITE w/black
3 Encoder power return ORANGE w/black
4 +5 VDC Encoder power ORANGE
9 MA yellow
13 /MA yellow w/black
Pre-made cables are available for IPA and P Series motors:
Cables to connect P series rotary motors to IPA series drives:
  • 71-032647-xx.....Encoder cable, Single-turn, xx length in meters 03, 05, 10, 20
  • 71-032751-xx.....Encoder cable, Multi-turn, xx length in meters 03, 05, 10, 20
  • 71-032681-xx.....Encoder cable, Single-turn, HIGH FLEX, xx length in meters 03, 05, 10, 20
  • 71-032752-xx.....Encoder cable, Multi-turn, HIGH FLEX, xx length in meters 03, 05, 10, 20
Cables to connect P series Direct Drive PM-DD rotary motors to IPA series drives:
71-032648-XX.....DD Motor feedback cable, xx in meters 03, 05, 10, 20
Feedback power is maintained by the IPA. If the battery fails, the IPA with fault with a feedback fault and the motor cannot be enabled until the battery is replaced.
The battery is only used while the IPA is powered down and thus under normal use will last 5years+ before needing replaced.
jw-sept 2016
