Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Cables - Encoder Cable Color Code and Specs
Pinout for P Series Drives
P Series Drive Pin Function P Encoder cable Wire
P Encoder Highflex cable
Motor Side
3 MA YELLOW YELLOW 1
4 /MA YELLOW w/black BLUE 6
5 SLO WHITE GREEN 2
6 /SLO WHITE w/black WHITE 7
7 Encoder power return ORANGE w/black BLACK 4
14 +5 VDC Encoder power ORANGE RED 9
Battery (RED) Grey BROWN 8
battery 0V (Black) Grey w/black GRAY 3
Note: Battery is a Toshiba ER6V / 3.6V Lithium
Pinout for IPA Drives
IPA Pin Function P Encoder cable Wire Motor Side
9 MA YELLOW 1
13 /MA YELLOW w/black 6
1 SLO WHITE 2
2 /SLO WHITE w/black 7
3 Encoder power return ORANGE w/black 4
4 +5 VDC Encoder power ORANGE 9
Battery (RED) Grey 8
battery 0V (Black) Grey w/black 3
Note: Battery is a Toshiba ER6V / 3.6 V Lithium
BiSS-C encoder power requirements:  5 V, 200 mA
BiSS-C Protocol Timing
P Series Protocol Timing Constraints
Symbol Parameter Conditions Min. Max. Unit
tMAS Permissible clock period ttimeout = 1.2 μs 100 2 × ttimeout ns
tMASH Clock signal high level duration - 50 ttimeout ns
tMASL Clock signal low level duration ttimeout = 1.2 μs 50 - ns
tREQ Req low level duration ttimeout = 1.2 μs 50 ttimeout ns
CLK (MA) Permissible clock frequency MA - - 10 MHz
Multi-Turn Serial Encoder BiSS-C Output Format
CDS
0/1 bits
MT
0/12/16/20/24 bits
ST
9-21 bits
ERR/NERR
1 bit
WARN/NWARN
1 bit
LC
0/6 bits
CRCPOS
6 bits
Breakdown of BiSS-C Multi-Turn Encoder Format
Data Field Description Data Length
CDS Control data slave 1 bit
MT Multi-turn resolution 16 bits*
ST Single-turn data length 21 bits
ERR/NERR Error bit 1 bit
WARN/NWARN Warning bit 1 bit
LC Enable life counter 0 bits
CRCPOS Checksum for position data 6 bits
* Multi-turn resolution does not apply to the PM-DD direct drive rotary motors. These motors do not maintain mult-turn position and do not transmit MT bits.
Resolution of P Series Motor Encoders
Motor Multi-Turn Resolution Single-Turn Resolution Single-Turn Data Length Alignment Bits
PM-FALxxxM8Nx 65,536 (16 bits) 262,144 (18 bits) 21 bits 3
PM-FBLxxAMKx 65,536 (16 bits) 524,288 (19 bits) 21 bits 2
PM-FCLxxAMKx 65,536 (16 bits) 524,288 (19 bits) 21 bits 2
PM-DDxxxxxx 0 (0 bits) 1,048,576 (20 bits) 21 bits 1
PDF Format Specification
P Series - BiSS.pdf
jw sept 2016
glh dec 2017
08JUL2019 DCLIFFE
13SEP2019 DCLIFFE -- Corrected typo on PM-DD single/multi-turn bits
20OCT2021 DCLIFFE -- Corrected typo on FCL row.  Added metadata.
glh Sept 2022 - added battery wire color codes for the high flex cables
  • cable
  • BiSS-C
  • P Series
  • IPA
  • encoder
