Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Reading Torque from Pseries drive
To read the P series actual torque, the easiest way to get this is to change the PDO inputs to 16#1600.  You don't need to change the outputs on the left. No changes needed within the program.
Then, if you go to EtherCAT IO mapping, you can input a variable name for the actual torque value and then you can use that variable within your program:
This is faster than doing an SDO transfer as the PDO is updated every EtherCAT cycle.
1/20/16jh
