Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Cable to Adapt G2 and G1 Motors to G3
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
This FAQ assumes your Generation 1 motor is compatible with a Generation 3 drive.  See the link at the bottom to evaluate compatibility.
Here are two cables that are helpful that adapt the G1 or G2 Dynaserv motor encoder cable (8pin Honda connector) to the Dynaserv G3 CN2 feedback connector (PCR-S20F):
example To connect DR1008B-115 motor (or DRG21008B-115) to DRG3-1008B-DO, use cable part number: G3-ADAPTER-DR
example To connect DM1015B-115 motor (or DMG21015B-115) to DMG3-1015B-DO, use cable part number: G3-ADAPTER-DM
Related FAQ:
glh  10/3/12
