Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Software - Example - Torque Limited Move for Clamping (with Video)
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
Here's is a sample program for showing how to do a torque limited move, such as for a clamping operation:
IPA_Sample_Clamping.txt
Sample Clamping program with new IPA & ETH servo - YouTube
2/8/16jh
