Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Compax3 Software - Communicating to the Compax3 I12T11 Indexer from a Panasonic PLC over DeviceNet
In the Panasonic PLC software,
Set the Poll Path to:
Input:  20 64 25 01 00 30 03
Output:  20 64 25 01 00 30 07
Set both the Input and output word length to 30 Bytes.
8/3/2016 nc
