Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Cables - Bend Radius
Bend Radius for P Series motor cables. Applies to 40, 60 and 80 mm motors.  Note that high flex cables should always be used if repeated flexing is expected.
Normal Flex High Flex
Power Encoder Brake        Power Encoder Brake
APCS-PNxxLS APCS-ENxxES APCS-BNxxQS APCS-PFxxLS APCS-EFxxES APCS-BFxxQS
Diameter 7 mm 7 mm 4.6 mm 7.0 mm 6.9 mm 5.9 mm
Bend Radius 140 mm 120 mm 95 mm 35 mm 35 mm 30 mm
14-Mar-2016 -jw
4DEC19 JD
09JUN2020 DCLIFFE -- Corrected high flex bend radius.
  • cable
  • bend
  • pseries
  • radius
