Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Software - Example - Cable Winding Application
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
Cable Winding Application using the IPA
Click on Link below to get a zipped file (957 kB) that contains 3 files:
Cable Winder zipped file
  1. Application Note:  This application note discusses winding cable, or any similar long, flexible material onto a spool.  This note briefly describes the equipment used in a simple cable winding application.  In addition, a complete programming example for the Intelligent Parker Amplifier (IPA) is included.  The machine operation sequence, along with an example HMI project, are also described.
  2. ACR-View Programming Example for Cable Winding using the IPA
  3. InteractXpress Example Project File for the IPA and XPR2
Application Note only:  Cable Winding Application Using the IPA
Cable Winder Machine
8 Mar2016 nc
modified 10May2016 nc
05MAY2021 DCLIFFE -- Fixed app note only link.  Updated metadata.
  • IPA
