Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base PAC320 and PACIO Replacement Hardware
      • Hardware-
        • How do I order a replacement SD card for my PAC controller?
        • No Boot Device Found
        • PAC320 and PACIO Replacement Hardware
        • PACIO Connector Part Numbers
        • Using analog PACIO modules
PAC and PACIO Replacement Hardware
PAC 3 pole power connector can be ordered through a local Parker distributor as p/n 43-026582-01
 (Alternatively, here is the vendor information:      Weidmuller p/n 1691120000)
PAC SD Card Cover can be ordered through a local Parker distributor as p/n 55-032026-01
PAC E-bus Cover can be ordered through a local Parker distributor as p/n 58-032217-01
PACIO 2 pole connector can be ordered through a local Parker distributor as p/n 43-026590-01
 (used on PACIO-400-2)
PACIO 18 pole connector can be ordered through a local Parker distributor as p/n 43-026591-01
(used on PACIO-441-01, PACIO-441-02, PACIO-442-02, PACIO-443-01, PACIO-443-03, PACIO-443-06, PACIO-451-03, PACIO-452-01, PACIO-452-02)
PACIO 36 pole connector can be ordered through a local Parker distributor as p/n 43-026592-01
(used on PACIO-411-00, PACIO-450-02, PACIO-450-03, PACIO-450-05, PACIO-450-13, PACIO-451-01)
How do I order a replacement SD card cover for my PAC controller?
How do I order a replacement power connector for my PAC controller?
 How do I order a replacement E-bus cover for my PAC controller?
How do I order a replacement PACIO connector for my PACIO module?
glh 3/2016
updated glh 3/2019
