Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Motors - Mechanical Tolerances
The following figure shows tolerances for P Series servo motor's output shaft and mounting surfaces. Dimensional drawings of each motor include details for these mechanical tolerances.
1. Mating concentricity of the flange O.D
2. Run-out at the end of the shaft
3. Perpendicularity between the flange face and output shaft
FBL series motors
  • drawings
  • P Series
