Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Motors - Shaft Load Ratings
Axial and Radial Load Ratings for P Series Motors.
Motor Series Motor Flange Size Radial Load Axial Load
N Kgf N kgf
PM-FAL 40 148 15 39 4
PM-FBL 62 206 21 69 7
PM-FCL 80 255 26 98 10
PM-FE 130 725 74 362 37
PM-FF 180 1548 158 519 53
PM-FG 220 1850 189 781 90
 (also listed in P Series Indexer User Guide)
jw 23-mar-2016
