Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Drives - Motor and Power Connector Terminals
P Series terminal block connectors are manufactured by Weidmuller.  They may be purchased from any vendor that sells Weidmuller components.  Part numbers are listed below.
*Parker doesn't stock or sell these connectors
Motor U/V/W Weidmuller Product Description Weidmuller Part Number
PD-04 BLT 5.08HC/03/180F SN BK BX 1844230000
PD-10 BLZP 5.08HC/03/180F SN BK BX 1944340000
PD-35 BLZ 7.62HP/03/180LR SN BK BX 1093440000
Power Input Weidmuller Product Description Weidmuller Part Number
PD-04 BLT 5.08HC/11/180F SN BK BX 1844310000
PD-10 BLZP 5.08HC/11/180F SN BK BX 1944420000
PD-35 BLZ 7.62HP/11/180LR SN BK BX 1165010000
29-March 2016, nc
