Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base S/SX Motors - Step motors with Brad Harrison Connectors (Yellow 5 pin)
  • Step Motors-
    • A/AX Motors - A vs M motors
    • LV/HV Motors - Customs
    • VS Motors - Motor Cables
Many Parker actuators (formerly AAD) including the ET electric cylinders and ER rodless actuators were ordered with step motors with quick disconnect connectors (Brad Harrison type, 5pin connectors). These are similar to our standard ES series step motors (that are the same as the S motors sold with the S/SX drives and Zeta motors sold with the Zeta/Zeta6000 drives).
Below are the motor codes used on the actuators and the different S motor part numbers for ordering replacements:
KEYWORDS: S57-5122, S51-8322, S57-10222, S57-5123, S57-8323, S57-10223, S83-6232, S83-9332, S83-13532, S83-6233, S83-9333, S83-13533, ZETA83, ZETA57, STEP MOTOR, ES21, ES22, ES23, ES31, ES32, ES33
3/31/16jh
