Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How do I configure and gear to the PACIO-454-01 Module?
The attached sample uses an external encoder fed into the PACIO-454-01 Encoder/Counter module as a Master source for a simple Gearing application.
It uses a 4000 count/rev encoder (post-quadrature) as the external encoder and a Parker P-Series EtherCAT drive as the motion axis the PAC is controlling.
Select the project that matches your version of Parker Automation Manager:
PAM1.4: Simple_Gearing_to_PACIO454_Encoder_PAM1.4
PAM1.2: Simple_Gearing_to_PACIO454_Encoder_PAM1.2
glh 4/2016
1NOV18 JD
  • configure
  • PACIO
  • module
  • gear
  • 454
