Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Interact Xpress Misc - Xpress Manager Archive
    • Interact (Legacy)+
    • Interact Xpress-
    • IXA / PCA+
Updates for Xpress Manager with the latest version can be downloaded from the product page here.
Xpress version Release notes:  Xpress Release Notes 3.1.txt
Xpress Manager can be used with previous version projects; they do not need to be updated.  Projects when opened can be updated if need be. For more information see Updating Xpress Project versions & Creating Backup Copy.
Previous released versions of Xpress Manager:
Interact Xpress CD-1 v2.0.4.zip
Interact Xpress CD-1 v2.1.3.zip
Interact Xpress CD-1 v2.1.4.zip
Interact Xpress CD-1 v2.1.5.zip
Interact Xpress CD-1 v2.1.6.zip
Interact Xpress CD-1 v3.0.zip
Interact Xpress CD-1 v3.1.zip
4/13/16jh
