Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Master Encoder for C3 EPL & ACR9040 system
      • 9000 (Legacy)-
        • ACR Order Code
        • EPL Drive Enable Status
        • ACR9000 Event Counters
        • Ethernet/IP Encoders
        • Maximum USB Cable Length
        • Senary Axis Flags
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
A master encoder can be wired into the C3-EPL's auxialliary encoder input and will be passed to the ACR9040 through the Ethernet Powerlink connection. The position is mapped to P38146. The velocity is mapped is P38147.
