Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Drives - Indexer Version - RS-422 Pin-out
To connect the P-Drive to Xpress or InteractX HMIs over RS-422 talking Modbus Protocol, use the Pin-out guide below.
(Click on the image for a larger view)
Edited DM 04/25/2019
  • Com2
  • Com1
  • PA
  • HPX
  • XT
  • EPX
  • RS422
  • IX
  • RJ45
  • Modbus
  • HPC
  • IPC
  • EPX2
  • PinOut
  • P-Drive
  • IPX
  • PA2
  • XPR2
