Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base IPA Cables - P Series Motors to IPA
    • IPA Drive/Controller-
      • IPA Hardware - DC Power
See Tables below.
P-Series Motors to IPA Drive/Controller Encoder Cables
Cable Orientation Product Number Description, encoder cables to IPA Drive
N/A 71-032648-xx PM-DD Series, direct drive motor
Front Facing Cables 71-032647-xx PM-FAL/FBL/FCL Series Motor
71-032681-xx PM-FAL/FBL/FCL Series Motor, high flexibility cable
71-032751-xx PM-FAL/FBL/FCL Series Motor, with battery for absolute encoder
71-032752-xx PM-FAL/FBL/FCL Series Motor, high flexibility cable with battery for absolute encoder
Rear Facing Cables 71-032682-xx PM-FBL/FCL Series Motor
71-032683-xx PM-FBL/FCL Series Motor, high flexibility cable
71-032753-xx PM-FBL/FCL Series Motor, with battery for absolute encoder
71-032754-xx PM-FBL/FCL Series Motor, high flexibility cable with battery for absolute encoder
 xx=Length in meters.  03,05,10, or 20
Rear Facing Cables cannot be used with PM-FAL (40mm) motors
P-Series Motor Power Cables, Flying Leads
Cable Orientation Product Number Description, power cables, flying leads
N/A APCS-PNxxYS PM-DD Series, direct drive motor
Front Facing Cables APCS-PNxxLS  PM-FAL/FBL/FCL Series Motor
APCS-PFxxLS PM-FAL/FBL/FCL Series Motor, high flexibility cable
Rear Facing Cables APCS-PNxxLSR PM-FBL/FCL Series Motor
APCS-PFxxLSR PM-FBL/FCL Series Motor, high flexibility cable
P-Series Brake Cables, Flying Leads, only required for motors with Brakes (separate power cable required)
Front Facing Cables APCS-BNxxQS  PM-FAL/FBL/FCL Series Motor
APCS-BFxxQS  PM-FAL/FBL/FCL Series Motor, high flexibility cable
Rear Facing Cables APCS-BNxxQSR PM-FBL/FCL Series Motor
APCS-BFxxQSR PM-FBL/FCL Series Motor, high flexibility cable
  • PM-FE
  • PM-FCL
  • PM-FF
  • PM-FAL
  • PM-FBL
  • PM-DD
