Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Cables - Motor Power and Encoder Cables
See Tables shown below.
P Series Motors to P Series Drives Encoder Cables
Cable Orientation Product Number Description, encoder cables to P Series Drive
N/A APCS-ENxxZS PM-DD Series, direct drive motor
Front Facing Cables APCS-ENxxES PM-FAL/FBL/FCL Series Motor
APCS-EFxxES PM-FAL/FBL/FCL Series Motor, high flexibility cable
APCS-ENxxES1 PM-FAL/FBL/FCL Series Motor, with battery for absolute encoder
APCS-EFxxES1
PM-FAL/FBL/FCL Series Motor, high flexibility cable with battery for absolute encoder
(Note - battery is a Toshiba ER6V / 3.6V Lithium - Parker does not offer this as a replacement component)
Rear Facing Cables APCS-ENxxESR PM-FBL/FCL Series Motor
APCS-EFxxESR PM-FBL/FCL Series Motor, high flexibility cable
APCS-ENxxES1R PM-FBL/FCL Series Motor, with battery for absolute encoder
APCS-EFxxES1R
PM-FBL/FCL Series Motor, high flexibility cable with battery for absolute encoder
 xx=Length in meters.  03,05,10, or 20
P-Series Motor Power Cables, Flying Leads
Cable Orientation Product Number Description, power cables, flying leads
N/A APCS-PNxxYS PM-DD Series, direct drive motor
Front Facing Cables APCS-PNxxLS  PM-FAL/FBL/FCL Series Motor
APCS-PFxxLS PM-FAL/FBL/FCL Series Motor, high flexibility cable
Rear Facing Cables APCS-PNxxLSR PM-FBL/FCL Series Motor
APCS-PFxxLSR PM-FBL/FCL Series Motor, high flexibility cable
P-Series Brake Cables, Flying Leads, only required for motors with Brakes (separate power cable required)
Front Facing Cables APCS-BNxxQS  PM-FAL/FBL/FCL Series Motor
APCS-BFxxQS  PM-FAL/FBL/FCL Series Motor, high flexibility cable
Rear Facing Cables APCS-BNxxQSR PM-FBL/FCL Series Motor
APCS-BFxxQSR PM-FBL/FCL Series Motor, high flexibility cable
 Rear Facing Cables cannot be used with PM-FAL (40mm) motors
There are not high-flex cables for the direct drive series motor power and feedback cables at this time.
7/1/16jh added note on high-flex cables for direct drive
11/2016 jw corrected R cables and added noted for FAL
6/28/18 gh changed not about DD high-flex cables, not available.
