Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What are the reference power supplies available to terminal connections on the 590+?
    • DC590+ Series-
      • Why won't my motor run?
The 590+ has ±10 VDC, +24 VDC supplies available to terminal connections.
More information on the terminals can be found in the manual and QuickStart located on the product page for the 590+ on Parker.com under the Product Support tab.
14JUN2016 LS
13JUN19 JD
  • 590+
  • power
  • terminals
  • reference
  • supplies
