Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What is the current overload rating for the 590+ drive?
  • AC/DC Industrial Drives-
    • DC590+ Series-
      • Why won't my motor run?
    • AC15/AC20+
    • DESAT (OVER I) Fault
The 590+ has an overload rating of 200% for 10 seconds and 150% for 30 seconds.
For more technical specifications, see the manual for the 590+ on Parker.com - under the Product Support tab.
14JUN2016 LS
  • rating
  • 590+
  • overload
