Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What are the minimum and maximum 3phase input ratings for the 590+?
  • AC/DC Industrial Drives-
    • DC590+ Series-
      • Why won't my motor run?
    • AC15/AC20+
    • DESAT (OVER I) Fault
What are the minimum and maximum 3-phase input voltage ratings?
The 590+ voltage rating is:
  • 110-500Vac (±10%) for ALL frame sizes
  • 500-600Vac (±10%) for frame 4, 6, and H
  • 600-690V (±10%) for frame 6 and H
14JUN2016 LS
17OCT2019 JD
  • voltage
  • minimum
  • rating
  • maximum
  • 590+
