Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What is the operating temperature for the 590+?
    • DC590+ Series-
      • Why won't my motor run?
The 590+ temperature rating is:
  • 0C to 45C (32F-113F) for the 15 amp through 675 amp rated drive.
  • i0C to 40C (32F - 104F) for the 850 amp through the 2400 amp rated drive.
Note: The drive has to be derated linearly 1% per degree centigrade from 45C (113F) up to a maximum of 55C (131F).
For more technical specifications visit the 590+ on Parker.com - Manual, QuickStarts, Product Support, etc under the "Product Support" tab.
14JUN2016 LS
  • operating
  • 590+
  • temperature
