Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What accessories can be added to the 590+?
    • DC590+ Series-
      • Why won't my motor run?
What options can be added to the 590+?
Speed Feedback, Communications, Remote mounting kit for the keypad, Dynamic Brake Contactor, Control transformer, and Blower Motor Starter are all potential options for the 590+.
For additional current information you can also contact your local Parker Automation Technology Center, or visit the 590+ on Parker.com  for manuals, QuickStarts, Product Support, etc
14JUN2016 LS
13JUN19 JD
  • options
  • 590+
  • accessories
