Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What are the Communication options for the 590+?
    • DC590+ Series-
      • Why won't my motor run?
The 590+ has many communication options available. For the modern Communication protocols available see the product page for the 590+ on Parker.com] - Includes manual, QuickStarts, Product Support, etc as well.
Some examples:
  • Ethernet IP
  • Modbus TCP
  • LinkNet
  • DeviceNet
14JUN2016 LS
13JUN19 JD
  • protocol
  • communication
  • 590+
