Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What are the communication settings for the 590+ for the P3 Port?
    • DC590+ Series-
      • Why won't my motor run?
When trying to communicate to the 590+ in DSELite, via the P3 port, you will need to set the baud rate in the COM selection to connect.   This is not the keypad port, instead the P3 port is next to the I/O terminals.
  • The baud rate is 9600. The communication mode is (EIASCII).
Note that you will be able to program through this port, but not download firmware to the drive (that requires the keypad port).
14JUN2016 LS
13JUN19 JD
  • P3
  • settings
  • 590+
  • port
