Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Can you download a DSELite file into the drive when the drive is running?
    • DC590+ Series-
      • Why won't my motor run?
No but you can EXTRACT the configuration from the drive, using DSE Lite, while the drive is running. Once the configuration is EXTRACTED you can Go Online with the drive to monitor parameters live.
14JUN2016 LS
13JUN19 JD
  • DSELite
  • running
  • Install
  • Extract
