Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Upgrading a control door from a 590 to a 590+
    • DC590+ Series-
      • Why won't my motor run?
Upgrading from a 590 to a 590+
Here is an application note about upgrading an existing 590 drive control door to a 590+. Do note that the 590 is obsolete, and an overall upgrade to the 590+ drive is recommended.
  • Link to document
[QuickLink for more Documentation for the 590+ on Parker.com] - Manual, QuickStarts, etc
14JUN2016 LS
  • Upgrade
  • 590+
  • control
  • door
  • 590
