Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What are the basic wiring connections required to run a motor, using the factory default drive?
    • DC590+ Series-
      • Why won't my motor run?
What are the basic wiring connections required to run a motor?
Here is an application note about the minimum connections required to run a motor with the 590+ with the factory default configuration.
  • Link to document
  • Do note that this information is also available in the Quickstart. If this is a new application, see the Quickstart on the product page (link below) to go through the basic setup process of implementing motor data, autotuning, wiring, etc.
  • [QuickLink for the 590+ on Parker.com] - Manual, QuickStarts, Product Support, etc
14JUN2016 LS
13JUN19 JD
  • quickstart
  • basic
  • 590+
  • simple
  • wiring
  • start
