Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Drives - Indexer Version - Product Overview
Download the P Series Indexer Product Overview using the link below.
P Series Indexer Product Overview (pdf, 12.1 MB)
The following documents are references:
P Series Indexer Scaling Product Note (pdf, 1 MB)
Interact Xpress P Series Indexer Project File (zipped file, 273 kB)
Product Overview covers the following topics:
  • P Series Servo Drives
  • Front Panel
  • System Configuration
  • Drive Support Software Brief Summary
Applications
  • Example Application: Feed-to-Length
  • Calculating scaling parameters, Setup Wizard, Test with I/O
  • Using with an XPR2 HMI running Interact Xpress
Other Features
  • Other Index Types
  • Homing
  • End-of-Travel Limits
  • Point-to-Point Motion and Jogging
  • Touch-probe (high speed input position capture)
Conclusion and Where to Find More Information
11 June 2016 nc
07DEC2021 DCLIFFE - Updated links, formatting and metadata.
  • indexer
  • P Series
