Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Drives - Indexer Version - How to do Scaling
How to do scaling on the P-Series Indexer Drive: P-Series Indexer Scaling Product Note
To simplify, to achieve desired User Units:
Motor Revolutions - Your PPR. The increments on your encoder per one shaft revolution.
Shaft Revolutions - The output of your mechanics.
  • If you have a leadscrew of 10mm, without a gearbox, your denominator here is 10 to achieve User Units of mm.
  • If you have a gearbox of 25:1 without a leadscrew (or a pulley), your denominator here is 25 to achieve User Units of revolutions on the gearbox output.
11 June 2016 nc
edited 15 Dec 2016 nc
15DEC2022 JD Clarification and tags
  • gear
  • ratio
  • scale
  • scaling
  • pseries
