Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What analog and digital I/O is available on the 590+?
  • AC/DC Industrial Drives-
    • DC590+ Series-
      • Why won't my motor run?
    • AC15/AC20+
    • DESAT (OVER I) Fault
Analog Inputs
The 590+ has five analog inputs, four configurable and one dedicated, rated for +/-10VDC, 1mA. All analog inputs have 12-bit resolution, (plus sign bit). Approximately 2.5mV/resolution. The inputs are scanned approximately every 10 milliseconds. The dedicated input connects directly to the SPEED LOOP or CURRENT LOOP (Analog Input 2 (A3)) and is scanned every 3 milliseconds.
Analog Outputs
The 590+ has three analog outputs, two configurable and one dedicated, rated for +/-10VDC, 5mA. The dedicated output connects directly to the CURRENT LOOP. The outputs are scanned approximately every 10 milliseconds. The analog outputs have 11-bit resolution (plus sign bit).
Digital Inputs
Digital Outputs
The 590+ has three digital outputs, all three are configurable, rated at +24VDC, 100mA (30VDC max). Note: The digital outputs are sourcing.
14JUN2016 LS
  • analog
  • digital input
  • digital output
  • 590+
