Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How can the 590+ be programmed?
  • AC/DC Industrial Drives-
    • DC590+ Series-
      • Why won't my motor run?
    • AC15/AC20+
    • DESAT (OVER I) Fault
How can the 590+ be configured?
  1. The 590+ can be programmed using our free DSELite software and is the recommended programming method.
    1. Follow this FAQ link for a guide to Install/Extract the configuration using DSELite, what cable you will need to program, and where to download DSELite.
    2. DSELite has help files associated with each function block by right clicking the blocks and an overall software guide under "Help" at the top of the DSELite window.
  2. The 590+ can be configured using the keypad
    1. It is more difficult and time consuming to program using the keypad and is not recommended for robust applications.
    2. More complicated programming logic can not be done via the keypad.
14JUN2016 LS
13JUN19 JD
  • configure
  • 590+
