Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base LV/HV Motors - Customs
  • Step Motors-
    • A/AX Motors - A vs M motors
    • LV/HV Motors - Customs
    • VS Motors - Motor Cables
CUSTOM VERSIONS OF THE LV & HV MOTORS THAT PARKER CAN SUPPLY...
  • Encoder mounted on the back w/ plug in type encoder cable, NEMA 23 & 34 (most common sizes offered)
  • Extended motor cable up to 200' (integral to motor as opposed to spliced)
  • Round shaft
  • Keyed shaft
  • Vacuum Rated
These can be requested on a custom product request submitted via the local distributor.
Note - for custom designs there may be minimum order quantities and/or NRE charges for the initial development.
For brakes, we recommend using an in-line brake. Electroid has a brake line that does not require any additional holes as it mounts to the front face of the motor (FEB series) and has its own shaft out the front that mounts to the load.
