Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How can the drive configuration be reset to factory defaults?
  • AC/DC Industrial Drives-
    • DC590+ Series-
      • Why won't my motor run?
    • AC15/AC20+
    • DESAT (OVER I) Fault
This procedure can also be found in the manual.
  1. Hold the Up and Down arrows buttons.
    1. Power up of the drive.
    2. Release the arrow buttons when the display reads "calibrating".
  2. The second method is to install a default template from the software DSELite.
16JUN2016 LS
13JUN19 JD
  • reset
  • 590+
  • default
  • factory
