Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Why does the drive fault to "speed feedback"?
    • DC590+ Series-
      • Why won't my motor run?
Why does the drive fault to “speed feedback”?
The tachometer or encoder may be bad. Switch the drive speed feedback to armature voltage, and then verify normal operation.
Open up DSELite and monitor the feedback, is it good feedback?
Try swapping the option card, the cables, and the motor if at all possible to see if the issue follows one of those devices.
16JUN2016 LS
13JUN19 JD
  • fault
  • feedback
  • speed
