Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How can I upgrade a 590+ Frame 1 or 2 drive version 5.x or 7.x to version 8.x - Control Board and Configuration
    • DC590+ Series-
      • Why won't my motor run?
How can I upgrade a 590+ Frame 1 or 2 drive version 5.x or 7.x to version 8.x?
This document will explain how to upgrade a 590+ Frame 1 or Frame 2 with firmware v5.x or v7.x to a v8.x. control board, and migrating the configuration. This is not a firmware update for an existing control board. This is an entire replacement of the control board to upgrade to a newer major revision, on the Frame 1 and 2 that utilizes the control "cradle" design.
  • To update to newer minor revisions of firmware use the DSELite software.
  • To update to newer major revisions of firmware, you must replace the control board.
  • Link to document
21JUN2016 LS
30May19 JD
  • board
  • Install
  • Upgrade
  • firmware
  • 590+
  • control
