Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How do I flash my 590+ drive to a newer Minor Revision of Firmware?
  • AC/DC Industrial Drives-
    • DC590+ Series-
      • Why won't my motor run?
    • AC15/AC20+
    • DESAT (OVER I) Fault
How do I flash my 590+ drive to newer Firmware?
You must use the keypad port, not the P3 port located next to the I/O. This document will explain how to flash a 590+ minor revision of firmware. To flash major revisions of firmware you must replace the control board.
  • Link to document
21JUN2016 LS
13JUN19 JD
  • firmware
  • 590+
  • 590
