Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Can I select between Manual Speed Reference and Line Speed Trim Setting for the same Analog Input?
    • DC590+ Series-
      • Why won't my motor run?
This document will explain how to use the same analog input to set the Manual Speed Reference and the Line Speed Trim.
  • Link to document
21JUN2016 LS
13JUN19 JD - Update
  • analog
  • input
  • trim
  • speed
  • 590+
  • line
  • reference
