Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base AriesCE - Recovering from Estop
    • Aries Drive (Discontinued)-
      • Controller (CE)-
        • Aries Controller Replacement
        • AriesCE - Recovering from Estop
        • Aries Controller (CE) - CIP Communications stop on all devices when one CIP device goes offline
        • Does the Aries-CE (Controller Version) Offer an Analog Output
        • Downloading OS: Status: Failure Writing Data to Control
        • Drive Disable Delay for Brakes
        • How do I set the frequency in an ACR SINE move? (copy)
        • How to Convert an AriesPE (AriesEPL) to AriesCE
        • How to change IP address on Aries Controller
        • How to tell difference between Aries PE and CE?
        • My Aries controller boots directly to a red LED
        • System Pointer Address of Aries CE Global Variables, P0-P4095
      • Drive only (AE,AR, SE, SR)+
      • EPL+
      • Aries Brake Delay
      • E27 Bridge Hardware Fault
      • Manual Alignment Procedure
      • Aries drive won't enable
      • Selecting a Fuse
bit 10000 Control Power Active
This bit indicates the AriesCE is in keep alive. It is on when only logic power is on (voltage on C1/C2). This bit turns off when amplifier power is on (L1/L2) (immediately).
So in recovering from an estop, you can inhibit until this bit is off.
If monitoring this bit in the event that the AC power is turned off, use a discrete input as well; it takes a few seconds for the motor and amplifier circuitry to dissipate and so it takes a few seconds for this bit 10000 to turn on.
