Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How can I manually tune a 590+ drive to my motor?
    • DC590+ Series-
      • Why won't my motor run?
This document will explain how to manually tune a 590+ to drive a motor.
  • Link to document
Common Problems:
1. If the motor is re-wound, the motor specs may not match what is printed on the motor. This could cause an auto-tune to fail.
2. A rotating auto-tune will run the motor to base speed. If the voltage is low incoming to the drive, or the configured max speed is less than the base speed, the auto-tune will fail.
3. After Auto-Tune, users need to Save to Flash. If not, the drive will revert to previous values after cycling power and the auto-tune will need to be redone.
22JUN2016 LS
15MAY2022 JH Added notes
  • manual
  • tuning
  • 590+
  • tune
