Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How can I send ASCII strings to or from the PAC?
Below is a zipped file containing a document, video, PAM project archive, library and embedded Xpress project that will demonstrate and explain how to implement TCP/IP communication on the PAC, and use it to send ASCII strings.
Select the file that matches your version of Parker Automation Manager:
PAM1.4: PAC_Implementing_TCPIP_PAM1.4
PAM1.2: PAC_Implementing_TCPIP_PAM1.2
28JUN2016 DC
1NOV18 JD
  • PAC
  • ASCII
  • strings
  • send
