Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base P Series Drives - Indexer Version - ISELx pattern (Index Addressing Inputs)
ISEL0 ISEL1 ISEL2 ISEL3 ISEL4 ISEL5
Index0 0 0 0 0 0 0
Index1 1 0 0 0 0 0
Index2 0 1 0 0 0 0
Index3 1 1 0 0 0 0
Index4 0 0 1 0 0 0
Index5 1 0 1 0 0 0
Index6 0 1 1 0 0 0
Index7 1 1 1 0 0 0
Index8 0 0 0 1 0 0
Index9 1 0 0 1 0 0
Index10 0 1 0 1 0 0
Index11 1 1 0 1 0 0
Index12 0 0 1 1 0 0
Index13 1 0 1 1 0 0
Index14 0 1 1 1 0 0
Index15 1 1 1 1 0 0
Index16 0 0 0 0 1 0
Index17 1 0 0 0 1 0
Index18 0 1 0 0 1 0
Index19 1 1 0 0 1 0
Index20 0 0 1 0 1 0
Index21 1 0 1 0 1 0
Index22 0 1 1 0 1 0
Index23 1 1 1 0 1 0
Index24 0 0 0 1 1 0
Index25 1 0 0 1 1 0
Index26 0 1 0 1 1 0
Index27 1 1 0 1 1 0
Index28 0 0 1 1 1 0
Index29 1 0 1 1 1 0
Index30 0 1 1 1 1 0
Index31 1 1 1 1 1 0
Index32 0 0 0 0 0 1
Index33 1 0 0 0 0 1
Index34 0 1 0 0 0 1
Index35 1 1 0 0 0 1
Index36 0 0 1 0 0 1
Index37 1 0 1 0 0 1
Index38 0 1 1 0 0 1
Index39 1 1 1 0 0 1
Index40 0 0 0 1 0 1
Index41 1 0 0 1 0 1
Index42 0 1 0 1 0 1
Index43 1 1 0 1 0 1
Index44 0 0 1 1 0 1
Index45 1 0 1 1 0 1
Index46 0 1 1 1 0 1
Index47 1 1 1 1 0 1
Index48 0 0 0 0 1 1
Index49 1 0 0 0 1 1
Index50 0 1 0 0 1 1
Index51 1 1 0 0 1 1
Index52 0 0 1 0 1 1
Index53 1 0 1 0 1 1
Index54 0 1 1 0 1 1
Index55 1 1 1 0 1 1
Index56 0 0 0 1 1 1
Index57 1 0 0 1 1 1
Index58 0 1 0 1 1 1
Index59 1 1 0 1 1 1
Index60 0 0 1 1 1 1
Index61 1 0 1 1 1 1
Index62 0 1 1 1 1 1
Index63 1 1 1 1 1 1
