Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Parker MotionSizer: Stationary Rack, Moving Pinion
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • QM Series Motor Information
    • Smart Encoder Compatibility
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
For applications where the Rack is stationary and the Motor & Pinion are moving, set the rack's weight to an insignificant non-zero value.
Then for any additional load to the motor, set this with the Weight Only pull-down in the Axis Design screen. After selecting the motor, reiterate the sizing, adding the motor's weight (plus the gearhead if there is one) to the Weight Only value.
